11 years ago
Quartus 13.1 web edition : No .pof produced
I am using Quartus 13.1 Web edition and I have done a project that seems to work fine with .sof file programer.
And now, I would like to permanent program it, but no .pof file is in output file directory...
Do I have missed something ?
(My english is poor, sorry, french people are not so fluent in other language)
Thank in advance
Benoit
    You need to go to file -> convert programming file
    You create a .pof from the output .pof file.
    You can also create other formats from assignmnets-> device settings -> device and pin options -> programming files (but you cant create a pof this way).
    If you are getting a SOF, then it should generate a POF is you have the device setting to Active Serial.
    But you can still generate a POF from a SOF using the convert programing files under the files menu.
    If you are not getting a SOF, then you are probably targeting a newer device that only has advanced support enabled in 13.1
    Pete
    --- Quote Start ---
    Pete
    --- Quote End ---
    It's a good idea to have a look to the device settings 'Active Serial' but not enough !
    My alternate choice is your suggest : generate POF from SOF. And it works.
    But i did used older version of Quartus that automaticly generate the .POF, certainly I have to check box somewhere but i have not find which one.
    Thanks Pete and Tricky for your suggest.
    Benoit
