11 years agoIf you are getting a SOF, then it should generate a POF is you have the device setting to Active Serial.
But you can still generate a POF from a SOF using the convert programing files under the files menu. If you are not getting a SOF, then you are probably targeting a newer device that only has advanced support enabled in 13.1 Pete
