11 years ago --- Quote Start --- If you are getting a SOF, then it should generate a POF is you have the device setting to Active Serial. But you can still generate a POF from a SOF using the convert programing files under the files menu. Pete --- Quote End --- It's a good idea to have a look to the device settings 'Active Serial' but not enough ! My alternate choice is your suggest : generate POF from SOF. And it works. But i did used older version of Quartus that automaticly generate the .POF, certainly I have to check box somewhere but i have not find which one. Thanks Pete and Tricky for your suggest. Benoit
