8 years ago
Quartus -multiple versions on one PC
Are versions of Quartus installed as independent applications? I have 17.1 installed and now I need 15.x . Thanks.
    One note about this: if you open projects by double-clicking on their .qpf files, it may not open the version of the software you want. Adjust your environment variable (I forget which one it is) to point to the one you want to use, or be sure to open projects from within Quartus.
    --- Quote Start ---
    --- Quote End ---
    Basically, yes. They would be installed in entirely different directory structures. E.G., 17.1 under C:\Altera\Quartus\17.1, and 15.0 under C:\Altera\Quartus\15.0
    I then use a command script to set the appropriate environment variables to point to one or other of the directory trees. In my case I use a shell command script:
    #!/bin/bash#
    export QUARTUS_BASE=/cygdrive/C/Altera/Quartus/15.0
    export QUARTUS_ROOTDIR=${QUARTUS_BASE}/quartus
    if  ; then
      export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin64
    else
    fi
    export QSYS_ROOTDIR=${QUARTUS_BASE}/quartus/sopc_builder/bin
    export SOPC_KIT_NIOS2=${QUARTUS_BASE}/nios2eds
    under CYGWIN on Windows 7 64b, but there are lots of different ways to do this using windows batch command files or other programs.
