8 years agoQuartus -multiple versions on one PC
Are versions of Quartus installed as independent applications? I have 17.1 installed and now I need 15.x . Thanks.
8 years agoOne note about this: if you open projects by double-clicking on their .qpf files, it may not open the version of the software you want. Adjust your environment variable (I forget which one it is) to point to the one you want to use, or be sure to open projects from within Quartus.
