pp's avatar
pp
5 years ago
quartus联合modelsim仿真找不到altera_mf库
各位前辈好
我在使用quartus 16.0 标准版联合modelsim仿真时,用到了一个fir ip,但是在启动modlesim的时候,报了一个找不到altera_mf库的问题,不知道怎么解决,各位前辈帮忙解答一下
    • pp's avatar
      pp
      hi Nurina:
      我看了您给我发的文档,我可以告诉您上面的步骤,我应该都有做,下面是我的一些关键截图
      首先我已经执行了编译quartus 仿真库文件了,即Launch Simulation Library Compiler.,并且放在了 modlesim 软件的根目录下
      然后,我在生成FIR IP核的时候,也选择了生成仿真文件了
      最后呢,生成的quartus 仿真库文件,我也将里面的关键信息,复制到了modelsim.ini 文档下
      quartus 里对仿真环境的设置如下
      根据您给我的文档,我不知道我哪里出了问题,我觉得我所有步骤,都已经做了
    • pp's avatar
      pp
      If this is the problem, then I decide to use Modelsim-Altera to solve this problem, because I do not have the 10.4D Modelsim SE software, thank you for your answer
  • BrusC_Intel's avatar
    BrusC_Intel
    Hello, PP.
    Thank you for posting in the Intel Community Support forum.
    We have a specialized community section for this type of inquiry, and I will move this thread to that section so it can be answered as soon as possible.
    Bruce C.
    Intel Customer Support Technician
  • pp's avatar
    pp
    Dear brusc:
    谢谢你帮我转发至对应的社区板块,这个问题困扰我很久了,一直得不到解决,希望前辈们可以帮助我
  • Nurina's avatar
    Nurina
    Can you change the simulation environment in EDA Tools Options like so:
    C:/intelFPGA/16.0/modelsim_ase/win32aloem
    Let me know if this solves your problem.
    Nurina
    • pp's avatar
      pp
      dear Nurina:
      我不知道您的这个文件路径指向的是什么软件? 如果是指向的是modelsim 软件的根目录的话,我这边文件夹只有win64,没有win32的文件夹路径可选
    • pp's avatar
      pp
      dear Nurina:
      我用的modelsim 是第三方的工具,并不是intel quartus 的 modelsim - altera
  • Nurina's avatar
    Nurina
    OK. Since you didn't receive "executable cannot be found" error then I don't think this is a problem, the EDA tools setup should be fine.
    Can you attach your project? On Quartus, go to Project->Archive Project.. Then attach the .qar file here.
    Nurina
  • pp's avatar
    pp
    dear Nurina:
    按照您的步骤,我已经将工程的 .qar文件上传
  • Nurina's avatar
    Nurina
    Are you using Quartus Standard 18.0 or Quartus Standard 16.0?
    Nurina
  • pp's avatar
    pp
    Yes,i'm using Quartus Standard 18.0
  • Nurina's avatar
    Nurina
    You're welcome! I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Nurina
    PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
    • pp's avatar
      pp
      OK, I see. Thank you for your help and kind answer
