pp
5 years agoquartus联合modelsim仿真找不到altera_mf库
各位前辈好
我在使用quartus 16.0 标准版联合modelsim仿真时,用到了一个fir ip,但是在启动modlesim的时候,报了一个找不到altera_mf库的问题,不知道怎么解决,各位前辈帮忙解答一下
- 5 years ago
I was able to run your RTL simulation. Your problem is because your version of ModelSim (ModelSim 10.6d) is incompatible with your version of Quartus. Refer to Table 5 of this document for a list of compatible ModelSim versions: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-qts-std-dev-support-18.0.pdf#page=7
Nurina
Nurina
5 years agoHi,
Can you change the simulation environment in EDA Tools Options like so:
C:/intelFPGA/16.0/modelsim_ase/win32aloem
Let me know if this solves your problem.
Nurina
pp
5 years agodear Nurina:
我不知道您的这个文件路径指向的是什么软件? 如果是指向的是modelsim 软件的根目录的话,我这边文件夹只有win64,没有win32的文件夹路径可选
