quartus联合modelsim仿真找不到altera_mf库
- 5 years ago
I was able to run your RTL simulation. Your problem is because your version of ModelSim (ModelSim 10.6d) is incompatible with your version of Quartus. Refer to Table 5 of this document for a list of compatible ModelSim versions: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-qts-std-dev-support-18.0.pdf#page=7
Nurina
Is this FIR II IP? To simulate this IP you need to follow steps 2.4 of this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fir_compiler_ii.pdf#page=21
I believe you did not complete step 3, section 1.5.1 of this document expands on that: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-tp-simulation.pdf#page=7
Let me know if this helps.
Nurina
- pp5 years ago
hi Nurina:
我看了您给我发的文档,我可以告诉您上面的步骤,我应该都有做,下面是我的一些关键截图
首先我已经执行了编译quartus 仿真库文件了,即Launch Simulation Library Compiler.,并且放在了 modlesim 软件的根目录下
然后,我在生成FIR IP核的时候,也选择了生成仿真文件了
最后呢,生成的quartus 仿真库文件,我也将里面的关键信息,复制到了modelsim.ini 文档下
quartus 里对仿真环境的设置如下
根据您给我的文档,我不知道我哪里出了问题,我觉得我所有步骤,都已经做了
