quartus联合modelsim仿真找不到altera_mf库
- 5 years ago
I was able to run your RTL simulation. Your problem is because your version of ModelSim (ModelSim 10.6d) is incompatible with your version of Quartus. Refer to Table 5 of this document for a list of compatible ModelSim versions: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-qts-std-dev-support-18.0.pdf#page=7
Nurina
Nurina
If this is the problem, then I decide to use Modelsim-Altera to solve this problem, because I do not have the 10.4D Modelsim SE software, thank you for your answer
