pp
5 years agoquartus联合modelsim仿真找不到altera_mf库
各位前辈好
我在使用quartus 16.0 标准版联合modelsim仿真时,用到了一个fir ip,但是在启动modlesim的时候,报了一个找不到altera_mf库的问题,不知道怎么解决,各位前辈帮忙解答一下
- 5 years ago
I was able to run your RTL simulation. Your problem is because your version of ModelSim (ModelSim 10.6d) is incompatible with your version of Quartus. Refer to Table 5 of this document for a list of compatible ModelSim versions: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-qts-std-dev-support-18.0.pdf#page=7
Nurina
Nurina
5 years agoHi,
OK. Since you didn't receive "executable cannot be found" error then I don't think this is a problem, the EDA tools setup should be fine.
Can you attach your project? On Quartus, go to Project->Archive Project.. Then attach the .qar file here.
Nurina
