qsys-script: invalid command name
Hello everybody,
I would like to run the .tcl script i exported from GUI wizard to generate the design without the GUI.
I wrote a .tcl script which includes the line:
qsys-script --script=internal_osc.tcl --package-version=16.0
When i run my script, i gen an error:
invalid command name "qsys-script"
while executing
"unknown_original qsys-script --script=internal_osc.tcl --..."
("eval" body line 1)
invoked from within
"eval unknown_original $cmd $args"
(procedure "::unknown" line 7)
invoked from within
"qsys-script --script=internal_osc.tcl --package-version=16.0"
(file "synthProject.tcl" line 12)
I noticed a thread with a similar problem (https://forums.intel.com/s/question/0D50P00003yyOXWSA2/qsysscript-problems ), but additional package-version parameter doesn't solve my problem. Does anybody have an idea what is the problem with my script.
Klemen
- sstrell
Do you have a package require line at the top of internal_osc.tcl as mentioned in the user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
#iwork4intel
- fogl
Yes i have. This file was generated by quartus.
internal_osc.tcl
# qsys scripting (.tcl) file for internal_osc
package require -exact qsys 16.0
create_system {internal_osc}
set_project_property DEVICE_FAMILY {MAX 10}
set_project_property DEVICE {10M02SCU169C8G}
set_project_property HIDE_FROM_IP_CATALOG {true}
# Instances and instance parameters
# (disabled instances are intentionally culled)
add_instance int_osc_0 altera_int_osc 19.1
set_instance_parameter_value int_osc_0 {CBX_AUTO_BLACKBOX} {ALL}
set_instance_parameter_value int_osc_0 {CLOCK_FREQUENCY_1} {116}
set_instance_parameter_value int_osc_0 {CLOCK_FREQUENCY_2} {77}
# exported interfaces
set_instance_property int_osc_0 AUTO_EXPORT {true}
# interconnect requirements
set_interconnect_requirement {$system} {qsys_mm.clockCrossingAdapter} {HANDSHAKE}
set_interconnect_requirement {$system} {qsys_mm.enableEccProtection} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.insertDefaultSlave} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.maxAdditionalLatency} {1}
save_system {internal_osc.qsys}
- fogl
And the .tcl script i run:
package require ::quartus::project
- RichardT_altera
Do you execute the script in the command shell?
I am able to run your script though and get warning messages instead of an error.
- fogl
Yes, i run the script in shell.
I am using linux - Ubuntu 18.04.1 LTS.
- RichardT_altera
Have you tried to execute the command in the Nios II command shell?
- fogl
I was not aware this is possible. What is the command to run the .tcl script in nios II?
I found the intelFPGA_lite/19.1/nios2eds/nios2_command_shell.sh, if i run it it returns this:
Altera Nios2 Command Shell
Version 19.1, Build 670
I was experimenting with options acording to exec: usage: exec [-cl] [-a name] [command [arguments ...]] [redirection ...] but no luck.
- RichardT_altera
You can run again your tcl script:
- fogl
I was able to execute this command and it seems this solved the problem, Thank you for your help :)
- RichardT_altera
I am glad that the issue solved. ;)
