qsys-script: invalid command name
Yes i have. This file was generated by quartus.
internal_osc.tcl
# qsys scripting (.tcl) file for internal_osc
package require -exact qsys 16.0
create_system {internal_osc}
set_project_property DEVICE_FAMILY {MAX 10}
set_project_property DEVICE {10M02SCU169C8G}
set_project_property HIDE_FROM_IP_CATALOG {true}
# Instances and instance parameters
# (disabled instances are intentionally culled)
add_instance int_osc_0 altera_int_osc 19.1
set_instance_parameter_value int_osc_0 {CBX_AUTO_BLACKBOX} {ALL}
set_instance_parameter_value int_osc_0 {CLOCK_FREQUENCY_1} {116}
set_instance_parameter_value int_osc_0 {CLOCK_FREQUENCY_2} {77}
# exported interfaces
set_instance_property int_osc_0 AUTO_EXPORT {true}
# interconnect requirements
set_interconnect_requirement {$system} {qsys_mm.clockCrossingAdapter} {HANDSHAKE}
set_interconnect_requirement {$system} {qsys_mm.enableEccProtection} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.insertDefaultSlave} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.maxAdditionalLatency} {1}
save_system {internal_osc.qsys}
