13 years ago
Qsys new component - file path keeps changing
i am working on my first Qsys project and it is running smooth with all built in components and one custom unit i connected in my .bdf file.
However, i was trying to a add the I2C unit from Altera wiki by the following steps:
  1. New component (in Qsys)
  2. add the top module to files (i2c_opencores.v)
  3. Analyze file and connect all signal to the avalon counterpart and assign everything in interfaces and edit some names
  4. no errors or warnings appear and i save
  5. adding to system content is fine too
  6. THEN: when i edit the file again or just generate and compile in quartus i get the errors
edit again error: Error: add_fileset_file: No such file .../VHDL/i2c_opencores/vhdl/i2c_opencores/i2c_opencores.v
the path is doubled??
same during compilation:
Error (12252): ...: add_fileset_file: No such file .../TDC_FPGA/VHDL/i2c_opencores/VHDL/i2c_opencores/i2c_opencores.v
no matter how often i specify the correct path it always returns to the wrong path!
Any ideas someone?
EDIT: i dont get this pathchange if i dont edit any names and leave everythin "as is".
EDIT2: however it also happens if i add multiple files!
