12 years ago --- Quote Start --- I'm having the same problem too. The Qsys 'details' dialog box shows the right path, but the component editor wouldn't allow me to change the faulty path regardless how many times i try. I solved it by deleting the tcl, and remaking the component. Not a novel workaround perhaps? but there's nothing else i can do. --- Quote End --- Qsys Component editor gave me a lot of trouble. The workaround that I am using right now is fairly simple until they fix the bug. I use SOPC builder component editor. It is easier than the one in Qsys. My file system looks like this (A qsys subsystem that needs to integrate a custom component ) /Qsys_subsystem_alphaQsys_subsystem_alpha.qsys Custom_component_hdl/ custom_component_top.vhd custom_component_hw.tcl When you open the subsystem with Qsys it will display the custom component and you can add it to your design. the _hw.tcl file is made by SOPC builder. It works for components with multiple synth files
