10 years agoQsys mm_interconnect - how to control size
I've got a largeish QSYS system with HPS and VIP suite modules, some dual-port RAM, etc. I've got a JTAG-MM Master hooked up to the control ports of the VIP modules, and I've got the HPS LW_AXI hooked up to those same control ports and some of the dual-port RAM. When my QSYS system is built, I get 5 mm_interconnect modules, and 4 of them are some 300-600 ALMs and the 5th is nearly 4000 ALMs. I've got them all clocked with the same clock, but for some reason this interconnect needs to take up a large percentage of my chip which I can ill afford. Would it be better to use the full AXI bus, not the lightweight one?
Cheers, Simon
