Altera_ForumHonored Contributor9 years agoQsys mm_interconnect - how to control size I've got a largeish QSYS system with HPS and VIP suite modules, some dual-port RAM, etc. I've got a JTAG-MM Master hooked up to the control ports of the VIP modules, and I've got the HPS LW_AXI hook...Show More
Recent DiscussionsTiming analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
