Qsys generation get stuck
Hi everyone,
I have a problem generating a qsys core.
I'm using the Quartus 12.1 SP1 suite and when I try to generate the QSYS core the environment goes stuck on the line:
Info: rio: exec C:/altera/12.1sp1/quartus/../ip/altera/common/ip_toolbench/v1.3.0/bin/ip_toolbench.exe -n {-devicefamily:Stratix IV} -lib_dir:C:/altera/12.1sp1/quartus/../ip/altera/rapidio/lib -flow_dir:C:/altera/12.1sp1/quartus/../ip/altera/common/ip_toolbench/v1.3.0/bin -wizard:rapidio -silent -parameterization.p_serial:1 -parameterization.p_xgmii:0 -parameterization.p_VOD:2 -parameterization.mode_selection:SERIAL_1X -parameterization.phy_selection:stratixivgx -parameterization.p_SYNC_ACKID:0 -parameterization.p_SEND_RESET_DEVICE:1 -parameterization.p_LINK_REQUEST_ATTEMPTS:7 -parameterization.p_data_rate:2500 -parameterization.p_ref_clk_freq:125 -parameterization.p_RXBUFRSIZE:4 -parameterization.p_TXBUFRSIZE:8 -parameterization.auto_cfg_rx:1 -parameterization.p_rx_threshold_0:20 -parameterization.p_rx_threshold_1:15 -parameterization.p_rx_threshold_2:10 -parameterization.p_TRANSPORT:1 -parameterization.p_TRANSPORT_LARGE:1 -parameterization.p_GENERIC_LOGICAL:0 -parameterization.p_PROMISCUOUS:1 -parameterization.rio_p_maintenance_master_slave:NONE -parameterization.p_MAINTENANCE_WINDOWS:1 -parameterization.p_TX_PORT_WRITE:0 -parameterization.p_RX_PORT_WRITE:0 -parameterization.rio_p_io_master_slave:AVALONMASTERSLAVE -parameterization.p_IO_SLAVE_WIDTH:29 -parameterization.p_READ_WRITE_ORDER:0 -parameterization.p_IO_MASTER_WINDOWS:1 -parameterization.p_IO_SLAVE_WINDOWS:1 -parameterization.p_DRBELL_TX:0 -parameterization.p_DRBELL_RX:0 -parameterization.p_DRBELL_WRITE_ORDER:0 -parameterization.p_DEVICE_ID:0x0 -parameterization.p_DEVICE_VENDOR_ID:0x0 -parameterization.p_DEVICE_REV:0xffffffff -parameterization.p_ASSEMBLY_ID:0x0 -parameterization.p_ASSEMBLY_VENDOR_ID:0x0 -parameterization.p_ASSEMBLY_REVISION:0x0 -parameterization.p_FIRST_EF_PTR:0x100 -parameterization.p_BRIDGE:0 -parameterization.p_MEMORY:1 -parameterization.p_PROCESSOR:0 -parameterization.p_SWITCH:0 -parameterization.p_PORT_TOTAL:1 -parameterization.p_PORT_NUMBER:0 -parameterization.p_SOURCE_OPERATION_DATA_MESSAGE:0 -parameterization.p_DESTINATION_OPERATION_DATA_MESSAGE:0 -parameterization.p_x4_mode:0 -parameterization.p_IO_MASTER:1 -parameterization.p_IO_SLAVE:1 -parameterization.p_MAINTENANCE:0 -parameterization.p_MAINTENANCE_MASTER:0 -parameterization.p_MAINTENANCE_SLAVE:0 -parameterization.p_ADAT:32 -parameterization.p_UNDER_SOPC:0 -parameterization.p_IO_SLAVE_OUTSTANDING_NREADS:16 -parameterization.p_IO_SLAVE_OUTSTANDING_NWRITE_RS:8 -simgen_enable.language:verilog -simgen_enable.enabled:0 -parameterization.p_UNDER_QSYS:1 C:/Users/Giacomo/AppData/Local/Temp/alt7981_5817592242511903221.dir/0001_rio_gen//QSYS_CORE_rio.vThe implemented Qsys module includes the following IPs:
- PCI express IP
- Rapid IO IP
The generation is stalled and I can only terminate by task manager.
Does anyone know why and if there is a workaround about it?
Thank you all.
- KennyT_altera
Hi, This might happened if you do not have all the device install. Can you install the latest Quartus prime std 18.1? As there are alot bugs fix there. - KennyT_altera
Still facing the issue? - EFran7
Thanks for helping Ktan9,
the problem, however, is another.
I don't know why, maybe a bug in the environment, but if I compile the same project with Quartus 12.1 SP1 installed on 32-bit Windows operating system everything works correctly.
Unfortunately I could not change Quartus version.
I didn't understand the reason.
Therefore, anyone who needs to compile a Qsys core that includes the Rapid IO IP with Quartus 12.1SP1 must know that it is necessary to generate Qsys on a 32-bit operating system. It worked for me.
Thank you.
- KennyT_altera
You may have to check again on the OS support for Q12.1, as it is an old version of Quartus which might not support the new version of OS.
