11 years agoQSYS BFM Simulation VHDL Help
Hi, I have followed the tutorial QSYS Avalon-MM Master BFM Tutorial for SystemVerilog and VHDL Testbenches: http://www.alteraforum.com/forum/showthread.php?t=48928 Which I got working...
11 years agoHi Dave,
Thanks for replying about this. I am still having problems. I had a look at the msim_setup.tcl and it looks like the correct files are being compiled when I run the script. I also see them in a library in the modelsim window. I attempted to compile the library as you stated with vlib vmap and vcom but the not bound warnings persist when I run the elab. I have attached the msim_setup.tcl that was generated (with extension txt or it wouldnt upload), in the com function (line 173 and 174) there are vcom's for both adc files.
vcom "$QSYS_SIMDIR/submodules/adc_sample.vhd" -work adc_sample
vcom "$QSYS_SIMDIR/submodules/adc_qsys.vhd" -work adc_qsys
Are these incorrect? --- Quote Start --- your ADC _hw.tcl components need to define the files required for simulation as well as synthesis. --- Quote End --- Do I need to edit or include the *hw.tcl files somehow? To add to the confusion I noted in the component editor in qsys under files there is a VHDL Simulation Files window, do I need to have something in here? I have tried using the same file as the synthesis (there is a copy from synthesis files button) but this generates a warning the SIM_VHDL fileset must specify the top-level module name. There is also a simulation section in the qsys generate, do I need to use this? In the tutorial this wasnt required so im guessing I dont need to worry about either of these?
