11 years agoQSYS BFM Simulation VHDL Help
Hi, I have followed the tutorial QSYS Avalon-MM Master BFM Tutorial for SystemVerilog and VHDL Testbenches: http://www.alteraforum.com/forum/showthread.php?t=48928 Which I got working...
11 years agoWhen you simulate your Qsys system, all the files needed for simulation should ideally appear in msim_setup.tcl, eg., your ADC _hw.tcl components need to define the files required for simulation as well as synthesis.
Quartus Qsys is a little annoying when it comes to getting all the simulation files correct. I'll often use my own pre-compiled libraries for components. In your case, just compile the missing components, eg., create the library and compile your ADC source vlib adc_qsys vmap adc_qsys ./adc_qsys vcom -2008 -work adc_qsys <adc VHDL filename> Once you eliminate the warnings about missing components, your simulation should run. At that point you could write your own sim.tcl script that calls msim_setup.tcl and compiles the stuff that Quartus misses. Cheers, Dave
