kikoss's avatar
kikoss
2 years ago
Qaurtus automatically include files without using `include directives ?
Hello
Has Quartus a have a built-in feature to automatically include files without using `include directives in our Verilog source.
Must we explicitly specify the files to be included using `include in the Verilog code. ?
if a have a 3rd part IP where this is the case (they didnt used `include explicetely ) how should we expect to compile that on quartus ? (the 3rd part dont provide an altera version of the IP )
Thx
Kikoss
  • @ShengN_Intel it's a lot of work to give a minimal design based on the IP we have to compile
    However, seems we found some of the issues:
    Some issues were related to the fact that: The `include xyz.sv is not forwarded across the hierarchy, contrary to the VCS compiler, so the solution was to add those `include and import the specific package that's defined on the `include
    Another issue was related to the timescale: we removed it from the top-level design and
    Thx for everyone about the advice
  • sstrell's avatar
    sstrell
    Try adding the files to the project (Project menu -> Add/Remove Files).
  • ShengN_altera's avatar
    ShengN_altera
    Other ways will be make sure the include package or file at the directory where .qpf resides. Or set the library path.
    Sheng
    • kikoss's avatar
      kikoss
      Hello
      it didn't worked ..
      i want to make sure the issue is well described :
      The issue is that there are some structs defined on a specific file let say fileA
      Those structs are used on project files , let say fileB
      fileA name is not included on fileB (by 3rd parts vendor IP - asic vendor , they don't provide quartus version)
      on asic (vcs also ) flow its compiled well - by adding the location of fileA only
      on quartus , it didnt compiled , so i add the following : set_global_assignment -name SEARCH_PATH <fileA directory location >
      but , quartus get error : that the struct (defined on fileA) is not declared
      I tried what you suggests , to copy the file on .qpf directory , but still the same error ..
    ShengN_altera
    Possible to provide a minimal design for better understanding and testing?
    Sheng
  • kikoss's avatar
    kikoss
