Qaurtus automatically include files without using `include directives ?
- 2 years ago
@ShengN_Intel it's a lot of work to give a minimal design based on the IP we have to compile
However, seems we found some of the issues:
Some issues were related to the fact that: The `include xyz.sv is not forwarded across the hierarchy, contrary to the VCS compiler, so the solution was to add those `include and import the specific package that's defined on the `include
Another issue was related to the timescale: we removed it from the top-level design and
Thx for everyone about the advice
Other ways will be make sure the include package or file at the directory where .qpf resides. Or set the library path.
Sheng
- kikoss2 years ago
Hello
it didn't worked ..
i want to make sure the issue is well described :
The issue is that there are some structs defined on a specific file let say fileA
Those structs are used on project files , let say fileB
fileA name is not included on fileB (by 3rd parts vendor IP - asic vendor , they don't provide quartus version)
on asic (vcs also ) flow its compiled well - by adding the location of fileA only
on quartus , it didnt compiled , so i add the following : set_global_assignment -name SEARCH_PATH <fileA directory location >
but , quartus get error : that the struct (defined on fileA) is not declared
I tried what you suggests , to copy the file on .qpf directory , but still the same error ..
