11 years ago
Q14 Web edition replace top level out port with buffer
Hi
I've done a top layer entity with (of course) some out port. I also made a testbench in order to verify the design. The problem is that Quartus sometimes generate a post-fitting simulation same as the entity I declare but with a buffer port instead the out port. In this way I can't run the post-fitting simulation. I have to recreate the project, that is quite annoying. Any work around?
Thanks in advice
Filippo
    I assume you're referring to VHDL's buffer port mode? do you read the output in the file internally?
    Yes, most of them, but using an internal signal and not in the top level.. something like
    entity x is
    port(
    output : out std_logic
    architecture b of x is
    signal output_signal : std_logic;
    begin
    -- some logic that read also output_signal
    output <= output_signal;
    end b;
    I can only guess that the synth optimisations have removed your internal signal, and so then reading the output port is required - meaning it needs to be a buffer rather than output (in 1993 at least - this restriction is removed in 2008).
    try using a syn_keep attribute on the output_signal
    Any other work around? i prefer to not affect the vhdl code.
    thanks
