11 years ago
Programming HPS pins in Quartus II - Unused HPS Pins
Dear community,
On my PCB design, most of the HPS pins are unused - according to the pin connection guidelines, I should either 'Connect unused pins as defined in the Quartus II software' (for DDR3 related pins) or 'If unused, program it in Quartus as an input with a weak pull-up.'. However, I fail to do so with Quartus II.
While I'm perfectly able to program FPGA pins, I am stuck with the HPS pins.
How do I program HPS pins?
Also, when you go to
Quartus II software -> assignments -> settings -> devices -> unused pins.
Is this for all pins or just the FPGA pins?
Many thanks,
Adam
