17 years ago
Programmable watchdog in FPGA
Hi all..I am trying to implment a programmable (by microcontoller) watchdog using FPGA..I am using the Altera Megafunction lpm_counter for this purpose. However, my watchdog is generating a lot of warmings ('barking') some of them I don't understand how to fix...
Description: I am using the 50MHz onboard oscillator (DE2) as my clock input and put it through a PLL to generate a 10MHz clock (the lowest one can get from these buildin PLL)..then I am using counter1 to further divide this down to approximately 32787Hz (10,000,000/305) which should give me about 2 second if I am counting down from 65535 to 0 (16bit)...so here is my code...
The warming I am getting is:
Warning: Found combinational loop of 2 nodes
Warning: Node "inst1|COUNTDOWN_COUNTER|auto_generated|latch_signal[9]~995|combout"
Warning: Node "inst1|COUNTDOWN_COUNTER|auto_generated|latch_signal[9]~995|dataa"
and there are many of this kind...I am attaching the whole project zipped file to this post as well...any recommendataions are welcomed!
library ieee;
use ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.all;
entity WDT is
Generic
add_WDT: std_logic_vector (15 downto 0) := X"0044"
port
reset : in std_logic; -- Hardware reset line from ColdFire
timeout : out std_logic := '0';
datain : in std_logic_vector (15 downto 0);
dataout : out std_logic_vector (15 downto 0);
address : in std_logic_vector (15 downto 0);
CS : in std_logic;
RW : in std_logic;
TA : out std_logic := '1';
oe : out std_logic;
q_out : out std_logic_vector (15 downto 0);
clkin : in std_logic -- 10MHz input clock
end entity WDT;
architecture sys of WDT is
signal counter1: integer range 304 downto 0;
signal WDT: std_logic_vector (15 downto 0);
signal Timer: std_logic_vector (15 downto 0);
signal stop, flag, flag2, load: std_logic;
signal intclk: std_logic;
type STATE_TYPE is (S0, S1, S2, S3, S4, S5); -- Delay
signal SC, NS: STATE_TYPE;
component lpm_counter
generic
lpm_direction : STRING;
lpm_port_updown : STRING;
lpm_type : STRING;
lpm_width : NATURAL
PORT
aload : IN STD_LOGIC;
cnt_en : IN STD_LOGIC;
clock : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
data : IN STD_LOGIC_VECTOR (15 DOWNTO 0)
END COMPONENT;
begin
clock_divider: process -- this process will divide the 10MHz clock downto approximately 32787Hz
begin -- therefore, 65536 cycles corresponding to about 2 seconds.
wait until clkin'event and clkin='1';
counter1 <= counter1 + 1;
if counter1 = 304 then
intclk <= intclk xor '1';
counter1 <= 0;
end if;
end process;
SYNC_PROC: process -- These following processes take care of ColdFire writes/reads from the watchdog
begin -- to set and read the countdown time
wait until clkin'event and clkin = '1';
SC <= NS; -- move to next state
end process;
STATE_PROC: process (SC)
begin
case SC is
when S0 => -- S0 is generally a wait state
if CS = '0' and RW = '1' then -- ColdFire reads
NS <= S1;
elsif CS = '0' and RW = '0' then -- ColdFire writes
NS <= S3;
else
NS <= S0;
end if;
-- ColdFire reads (S1-S2)
when S1 =>
if (address = add_WDT ) then
NS <= S2;
else
NS <= S5;
end if;
when S2 =>
NS <= S5;
-- ColdFire writese (S3-S6)
when S3 =>
if (address = add_WDT) then
NS <= S4;
else
NS <= S5;
end if;
when S4 =>
NS <= S5;
when S5 =>
if CS = '1' then
NS <= S0;
else
NS <= S5;
end if;
end case;
end process;
READ_PROC: process
begin
case SC is
when S1=> -- ColdFire reads
TA <= '1';
oe <= '1';
when S2=>
dataout <= WDT;
TA <= '0';
oe <= '1';
when S3=> -- ColdFire writes
TA<= '1';
oe <= '0';
when S4=>
WDT <= datain;
TA <= '0';
oe <= '0';
when others =>
TA <= '1';
oe <= '0';
end case;
end process;
L0AD_PROC: process
begin
flag <= reset;
end process;
LOAD_PROC2: process
begin
wait until clkin'event and clkin='0';
flag2 <= flag;
end process;
load <= flag xor flag2; -- Create pulses when reset change states
COUNTDOWN_COUNTER : lpm_counter
generic map
lpm_direction => "DOWN",
lpm_port_updown => "PORT_UNUSED",
lpm_type => "LPM_COUNTER",
lpm_width => 16
PORT MAP (
aload => load, -- Use the previously created pulse as asynload signal to the counter.
clock => intclk,
q => Timer,
cnt_en => stop,
data => WDT
q_out <= timer;
stop <= '0' when timer = X"0000" else '1'; -- If counter reaches 0, stop the count down and
timeout <= not (stop); -- rise the timeout flag
end architecture;
