13 years agoproblems with real data type conversion to std_logic_vector
Hi, I'm doing an discrete PID controller, based on FPGA's, but I wanna do it using floating point maths, the first block I was doing was an integrator, but I got an issue, the generic parameters of my project are real values, and the port of the megawizard IP is an std_logic_vector (31 downto 0), i don't know how to cast from real to std_logic_vector(31 downto 0), here my code:
Library IEEE; use IEEE.STD_LOGIC_1164.ALL; --use IEEE.STD_LOGIC_ARITH.ALL; --use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.math_real.all; use IEEE.numeric_std.all; entity bloque_integrador is generic ( sample_time : real :=1.0e-3; gain : real :=1.0 ); port ( clk_50MHz : in std_logic:='0'; clk_sys : in std_logic :='0'; rst : in std_logic:='0'; int_in : in std_logic_vector(31 downto 0):=X"00000000"; int_out : out std_logic_vector(31 downto 0) ); end entity bloque_integrador; architecture structural of bloque_integrador is -------señales de conexion internas al modulo----- signal int_in_reg : std_logic_vector(31 downto 0); signal int_in_reg_amp : std_logic_vector(31 downto 0); signal int_out_reg : std_logic_vector(31 downto 0); signal acumulador : std_logic_vector(31 downto 0); signal clk_sys_n : std_logic; -------constantes del sistema----------------- constant factor_amplificacion : real:=(sample_time*gain); signal factor_amplificacion_vector : std_logic_vector(31 downto 0); -----------------componente multiplicador------------- COMPONENT amplifier_altfp_mult_nvo IS PORT ( aclr : IN STD_LOGIC := '0'; clk_en : IN STD_LOGIC := '1'; clock : IN STD_LOGIC; dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); END COMPONENT amplifier_altfp_mult_nvo; ----------------componente sumador--------------- COMPONENT sumador_altfp_add_sub_t8k PORT ( aclr : IN STD_LOGIC ; clk_en : IN STD_LOGIC ; clock : IN STD_LOGIC ; datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0); dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); END COMPONENT; begin -------------------declaraciones adicionales------------ factor_amplificacion_vector<=to_stdlogicvector(to_bitvector(factor_amplificacion)); clk_sys_n<=not(clk_sys); --------------declaracion del registro de entrada------------ reg_in: process(clk_sys, rst, int_in, int_in_reg) begin if rst='1' then int_in_reg<=(others=>'0'); elsif( clk_sys'event and clk_sys='1') then int_in_reg<=int_in; end if; end process reg_in; --------------declaracion del registro de salida------------ reg_out: process(clk_sys, rst,acumulador, int_out_reg) begin if rst='1' then int_out_reg<=(others=>'0'); elsif( clk_sys'event and clk_sys='1') then int_out_reg<=acumulador; end if; end process reg_out; ----------------componente multiplicador---------------- multiplicador: amplifier_altfp_mult_nvo PORT MAP ( aclr => rst, clk_en => clk_sys_n, clock => clk_50MHz, dataa => factor_amplificacion, datab => int_in_reg, result => int_in_reg_amp ); ---------------componente sumador---------- suma:sumador_altfp_add_sub_t8k PORT map ( aclr =>rst, clk_en => clk_sys_n, clock => clk_50MHz, datab => int_in_reg_amp, dataa => int_out_reg, result => acumulador ); ------------------------------ int_out <=int_out_reg; end architecture structural; thank you for read, I'll apreciate your help.
