Problems with ModelSIM 2020.1 Starter Edition
I finished the first version of my design and tried to simulate it. Works, but some changes requiered as usual.
Now I have to setup simulation every time from scratch. Defining the clock signal, clock periode and which signals should be in the wave panel.
As my design generate signals using a pwm, it is helpful to use the 'Analog View'. But it is boring to enter the same info over and over.
I searched the documentation how to save this settings, but no success. I only found something to save the results ... pretty fine but not helpful in my situation.
Please help me.
With best regards
Gerhard
- ShengN_altera
Hi Gerhard,
After making any changes to waveform like add signals, choose radix or etc in modelsim, you may save waveform format to reuse by going File -> Save Format. Will default to .do file something like …/project/simulation/modelsim/wave.do.
When you create new simulation, you can reload the waveform format by going to File -> Load -> Macro File and point to the desired .do files.
Best Regards
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- Gerhard56
Hi Sheng,
THAAANKS.
Worked as described.
Only one little bump in my road left. This don't restore the settings for my clock signal. I have still to right click at my clock signal and set the periode, because my periode didn't default to 100ns .. I need 83.33ns setting.
But it is much better now.
With best regards
Gerhard
- ShengN_altera
Hi Gerhard,
Ya that method cannot save clock period. Sorry for confusion. For clock period you can declare it in testbench like below example:
`timescale 1ns/1ps
reg clk;
test uut(
.clk(clk));...
initial begin
clk = 0;
forever begin
clk = #50 ~clk;
end
end
In this example the clock period is 100ns. You can try with 83.33ns.
Best Regards
Sheng
- ShengN_altera
Hi Gerhard,
Any further update or consideration on this thread or Should I consider the case to be closed?
Sheng
