15 years ago
Problem with SystemVerilog operator ++ in Modelsim
I have some problem simulating code using the SystemVerilog ++ operator. Consider the following example (I tested this on QuartusII Web edition 9.1sp2 using ModelSim AE):
--- Quote Start ---
module test_sv ();
logic clk = 0;
logic [7:0] cnt1 = 0;
logic [7:0] cnt2 = 0;
logic test, next_test = 0;
always# 10ns clk = ~clk;
always @ (negedge clk) next_test <= cnt1[0] & cnt2[0];
always_ff @ (posedge clk) begin
`ifdef PLUSPLUS
cnt1++;
`else
cnt1 <= cnt1 + 1;
`endif
end
`ifdef MOVE_CNT2
`ifdef PLUSPLUS
cnt2++;
`else
cnt2 <= cnt2 + 1;
`endif
end
`endif
always @ (posedge clk) begin
# 1;
assert(test == next_test);
end
`ifndef MOVE_CNT2
`ifdef PLUSPLUS
cnt2++;
`else
cnt2 <= cnt2 + 1;
`endif
end
`endif
endmodule
--- Quote End ---
Saving this as test_sv.sv and running the following ModelSim commands:
--- Quote Start ---
vlog test_sv.sv
vsim work.test_sv
run 100 ns
vlog +define+MOVE_CNT1 test_sv.sv
restart -f
run 100 ns
vlog +define+PLUSPLUS test_sv.sv
restart -f
run 100 ns
vlog +define+PLUSPLUS +define+MOVE_CNT1 test_sv.sv
restart -f
run 100 ns
--- Quote End ---
The two first simulations work fine. They both avoid the ++ operator. The two last simulations result in errors. Actually they differ in result if you examine the waveforms.
It seams that QuartusII will synthesis the cnt1++ equivalent as cnt1 <= cnt1+1. i.e. there is a mismatch between simulation and synthesis result.
Does anybody know if there is any special considerations that must be made when using ++ operator?
Should this work or am I missing something?
/Henrik
1 Reply
    I think cnt1++ is
    equivalent to cnt1 = cnt1+1
    and not to cnt1 <= cnt1+1
    One is immediate the other is a deferred assigment.
