Problem with Quartus prim standard 24.1: I cannot generate IP for the hardware memory controller of
Hello, Richard-san.
I had already performed the process on this page.
https://www.intel.com/content/www/us/en/docs/programmable/683472/25-1/operating-system-requirements.html
Next, I referred to the Hardware and Software requiremants page and downloaded and installed the Latest Microsoft Visual C++ Redistributable Version.
However, the result was the same script error. Therefore, I reinstalled Quartus Prime standard 24.1.
I confirmed that Nios II SBT for Eclipse via eclipse-nios2.exe started.
https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
After that, I tried to generate the LPDDR2 IP again, but the result was the same.
What else could you think of?
Regards, Hidetaka.
Hello, Richard-san.
When I saw the error message, the error was in the "Info: LPDDR2_top2: Generating example design" item,
so I thought maybe I just shouldn't generate the example design, so I ran it, and it was generated without any errors.
Error: Execution of script "/0008_LPDDR2_top2_gen/simulation/generate_sim_example_design.tcl" is causing an error,
so I would appreciate it if you could fix this part.
Regards, Hidetaka.
- RichardT_altera1 year ago
Just to confirm, is it just the IP or the example design is generated successfully without ticking the "Generate Example Design" ?
Richard Tan
