Problem with Quartus prim standard 24.1: I cannot generate IP for the hardware memory controller of
The error message do stated that the WSL is required to run.
Could you try to install the WSL and see if the issue still occur?
Richard Tan
- Hidetaka1 year ago
Hello, Richard Tan-san.
I successfully installed wsl 1 and Ubuntu-18.04 on Windows 11.
Then I downloaded CDT 8.8.1 following the instructions on the page below.
https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
So I tried to generate LPDDR2 IP again with megawizerd of Quartus Prime standard 24.1.
The error <Nios II Command Shell.bat> that appeared before has disappeared,
but the following error appears and I still cannot generate IP.///////
Error: Execution of script C:/Users/ueshima-h/AppData/Local/Temp/alt0222_1666408435099083815.dir/0008_LPDDR2_top2_gen/simulation/generate_sim_example_design.tcl failed
Error: Info: *******************************************************************
Error: Info: Running Quartus Prime Shell
Error: Info: Version 24.1std.0 Build 1077 03/04/2025 SC Standard Edition
Error: Info: Copyright (C) 2025 Altera Corporation. All rights reserved.////////
Hidetaka.
