15 years ago
problem with changing pin assignments
I almost finished my FPGA & board design .
I wanted to add the possibilities to use CRC error check and dev_clr.
the pins dedicated for those functions are already being used for other purpose ( I used back annotation so the pin assignments are fixed) . when I tried to change the pin assignments to other pins , the compilation failed .
why is that ? how can I fix it ?
thanks...
    --- Quote Start ---
    --- Quote End ---
    failed how? (with which error message?)
    the error massage is:
    Error: Can't place multiple pins assigned to pin location Pin_E19 (IOPAD_X17_Y74_N0)
    Info: Pin RO_in[97] is assigned to pin location Pin_E19 (IOPAD_X17_Y74_N0)
    Info: Pin ~ALTERA_CRC_ERROR~ is assigned to pin location Pin_E19 (IOPAD_X17_Y74_N0)
    it looks like it doesn't Remember that I changed the pin assignments .
    How do I fix that?
    The error message says that you have a user pin "RO_in[97]" assigned to the location of CRC output.
    I know...
    But even after I changed it manually in the pin planer( I assigned RO_in[97] to pin E18 ), when I compile it ,the compiler ignores the change I made .
    Sometimes the pin planner operation is a bit arbitrary. I don't know what's exactly going on in your design but you usually have unlimited control in the assignment editor. You can also temporarily remove the said pin from the top entity port.
    It's possibly annoying, but a trivial issue, though.
    update:
    I tried to delete the signal and then I added it back ( after compilation) and it worked... thanks
    Hi
    I exactly have the same problem can you please tell me
    exactly step by step tell me how you solved this problem?
    Error: Can't place multiple pins assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0)
    Info: Pin Txd is assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0)
    Info: Pin ~ALTERA_NCEO~ is assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0)
    I would appreciate your advices
    I did a long time ago , but I think that what i did is:
    I deleted the assignment from the top level entity
    compiled the program
    I put it back in the top level entity.
    you may just change the names of the signals , maybe it'll also work .
    hi,
    just want to share my finding: based on your info below:
    if you take a look at the pin-out table for the device you are using. Mine if EP4CGX15, you can find programming pin NCEO is using the pin_N5. In order to to make this pin dual purpose pin and free up this pin after the programming purpose. You can do the follow:
    1. Open your Quartus Project. from the Quartus menu, Select Assingments -> Devices....
    2. Click Device and pin Options... button
    3. Select Dual-Purpose Pins from the Category column
    4. Under Dual-purpose pins: column, selct the NCEO as Use as regular I/O
    That's it. recompile your project, it should work this time. :):):)
