13 years agohi,
just want to share my finding: based on your info below: Error: Can't place multiple pins assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0) Info: Pin Txd is assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0) Info: Pin ~ALTERA_NCEO~ is assigned to pin location Pin_N5 (IOPAD_X10_Y0_N0) if you take a look at the pin-out table for the device you are using. Mine if EP4CGX15, you can find programming pin NCEO is using the pin_N5. In order to to make this pin dual purpose pin and free up this pin after the programming purpose. You can do the follow: 1. Open your Quartus Project. from the Quartus menu, Select Assingments -> Devices.... 2. Click Device and pin Options... button 3. Select Dual-Purpose Pins from the Category column 4. Under Dual-purpose pins: column, selct the NCEO as Use as regular I/O That's it. recompile your project, it should work this time. :):):)
