Altera_ForumHonored Contributor15 years agoproblem with changing pin assignments Hi, I almost finished my FPGA & board design . I wanted to add the possibilities to use CRC error check and dev_clr. the pins dedicated for those functions are already being used for othe...Show More
Altera_ForumHonored Contributor15 years ago --- Quote Start --- the compilation failed --- Quote End --- failed how? (with which error message?)
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolved
