Iam trying to dockerize intel_rte_stack. After dockerization, the docker container was able to detect fpgas attached via PCIe with
fpgainfo fme
Output:
root@4a694037e7ce:~# fpgainfo fme
Board Management Controller, microcontroller FW version 26895
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id : 0xEF00000
PCIe s:b:d:f : 0000:86:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x124000200000367
Bitstream Version : 1.2.4
Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c
Boot Page : user
But when I try to run aocl install, the following errors occurs and it says, Intel PAC device
root@4a694037e7ce:~/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl# aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /opt/Intel/OpenCL/Boards
aocl install: Adding the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
WARNING: Intel PAC device not found
Can someone please help me out in resolving these issues or if you have some proper documentation, please share
