8 years agoProblem with aocl install
Hi, I have a problem with the installation command "aocl install<path_custom_platform>", because of the bash returns the following problem: "is not an object at /home/intel_tools/intelFPGA_pro/1...
Saikiranbelana
4 years agoIam trying to dockerize intel_rte_stack. After dockerization, the docker container was able to detect fpgas attached via PCIe with
fpgainfo fme
Output:
root@4a694037e7ce:~# fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEF00000 PCIe s:b:d:f : 0000:86:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : user
But when I try to run aocl install, the following errors occurs and it says, Intel PAC device
root@4a694037e7ce:~/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl# aocl install Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege Install the FCD file to /opt/Intel/OpenCL/Boards aocl install: Adding the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages Installing the board package driver to the system. aocl install: Running install from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec WARNING: Intel PAC device not found
Can someone please help me out in resolving these issues or if you have some proper documentation, please share
