8 years agoProblem with aocl install
Hi, I have a problem with the installation command "aocl install<path_custom_platform>", because of the bash returns the following problem: "is not an object at /home/intel_tools/intelFPGA_pro/1...
8 years ago --- Quote Start --- And the workaround is?? --- Quote End --- You probably didn't see the link that reads: --- Quote Start --- Workaround To avoid this error, apply following changes to the <OpenCL SDK Installation Path>/share/lib/perl/acl/Command.pm: lines 110 &111 Line 110: Replace isWindowsOS() ->acl::Env::is_windows() Line 111: Replace mysystem_full({}, @cmd); -> system(@cmd); --- Quote End ---
