8 years agoProblem with aocl install
Hi, I have a problem with the installation command "aocl install<path_custom_platform>", because of the bash returns the following problem: "is not an object at /home/intel_tools/intelFPGA_pro/1...
8 years ago --- Quote Start --- I just wanted to add that it seems this was fixed in SDK v17.1 Update 1. The update release notes (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rn/rn_qts_dev_support_update.pdf) at page 18 reads:
Fixed an issue where the aocl install command failed with message similar to
the following example:
is not an object at <path_to_command.pm>/Command.pm line 1241, <F> line 68. --- Quote End --- I don't think it has been released yet, at least, I can't find it...
