Engineer87
2 years agoProblem in Quartus Prime I++ HLS Compiling "The command line is too long."
hello every one. I got sticky problem in compiling my C++ code. when compiling wants to be finished the compiler stops and showing this message: The command line is too long. HLS Main Optimizer ...
- 2 years agoI finally found the solution. The answer is : compiling c++ code in fpga mode with i++ compiler needs a huge amount of Ram and hdd resource for page filing. For example a cycloneV design needs about 64gb ram and resource. it depends on your design. That is it.
BoonBengT_Altera
Moderator
2 years agoHi @Engineer87,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
Engineer87
2 years agoI do appreciate your attention and time. Thnx again.
