Engineer87
2 years agoProblem in Quartus Prime I++ HLS Compiling "The command line is too long."
hello every one. I got sticky problem in compiling my C++ code. when compiling wants to be finished the compiler stops and showing this message: The command line is too long. HLS Main Optimizer ...
- 2 years agoI finally found the solution. The answer is : compiling c++ code in fpga mode with i++ compiler needs a huge amount of Ram and hdd resource for page filing. For example a cycloneV design needs about 64gb ram and resource. it depends on your design. That is it.
BoonBengT_Altera
Moderator
2 years agoHi @Engineer87,
Noted on the project files as well as the error logs.
Allow us some time to check on the situation and will get back at earliest.
Thank you for the patients
Best Wishes
BB
