Engineer87
2 years agoProblem in Quartus Prime I++ HLS Compiling "The command line is too long."
hello every one. I got sticky problem in compiling my C++ code. when compiling wants to be finished the compiler stops and showing this message: The command line is too long. HLS Main Optimizer ...
- 2 years agoI finally found the solution. The answer is : compiling c++ code in fpga mode with i++ compiler needs a huge amount of Ram and hdd resource for page filing. For example a cycloneV design needs about 64gb ram and resource. it depends on your design. That is it.
BoonBengT_Altera
Moderator
2 years agoHi @Engineer87,
Thank you for posting in Intel community forum and hope all is well.
May I know what are the HLS version you are having?
And also would it be possible to share the .cpp files you have for us to simulate the issues?
Hope to hear from you soon.
Best Wishes
BB
- Engineer872 years ago
hello
At first thanks for your answer. yes my Quartus prime version is 17.1
my code is image processing and I share it to you...
the command line and log is in attachment.
sincerely.
