10 years ago
Prevent instantiation of clock driver
Hi all,
to debug a design I have routed several clock signals to FPGA output pins (so that I can measure them). As a consequence, the compilation failed, because the fitter could not place one of the corresponding clock drivers:
Error (14986): After placing as many components as possible, the following errors remain:
Error (175001): The Fitter cannot place 1 global or regional clock driver.
Info (14596): Information about the failing component(s):
Info (175028): The global or regional clock driver name(s): cam_lsvds:cam_lsvds_1|altlvds_rx:ALTLVDS_RX_component|cam_lsvds_lvds_rx:auto_generated|cam_lsvds_altclkctrl:rx_outclock_buf|sd7
As this is only for debugging purposes I would like to disable the instantiation of a clock driver for this specific signals. Is this possible, maybe in the assignment editor?
    PLL's can only drive globals. There is physically no way to have them use local routing. Something else will need to be demoted.
