AEsqu
Contributor
3 years agoPreservation level: Final leads to Quartus crash on re-run
Preservation level: Final leads to Quartus crash on re-run. Quartus does not crash when I use the synthesize preserve level (or no preserve). Crash log + picture after the crash message (closed). ...
Nurina
3 years agoYes it's an ini password, it would disable dangling routes.
Based on the IE case report, this IE is suspected to be a side effect of a PR-related fix. If you have a core clock driving to the periphery then there will be dangling route issue and Quartus throws this IE.
All you need to do is change the extension of the above quartus.txt file to .ini, save it to the same directory as your .qpf file and run compilation.
Nurina
- AEsqu3 years ago
Contributor
Thank You for the explanation.
I'm running it on 22.4 as 23.1 is still not working at our side (seems that Quartus 23 is not able to pick the license correctly from a pool).
