13 years ago
PLL Megawizard broken in Quartus 13.1?
I just noticed, that the PLL Megawizard does not start up in Quartus 13.1 any more, neither when creating a new component, nor when editing an existing one. The blue "Loading Megawizard" window shortly appears on the screen, and then diappears. I can confirm that the PLL megawizard still worked in Quartus 13.0sp1. In the task manager I can see, that a java process appears in the list for a second or so, but then it disappears again. If I enable the task manager to show the command line of the process, the line appears incompletely to me: "c:/altera/13.1/quartus/bin/jre/bin/javaw.exe" -Xms64m -Xmx 1g -jar "c:/altera/13.1/quartus//sopc_builder/model/lib/com.altera.iplauncher.jar" "--wizard=altera_pll" "--early_gen=on" "--wizard_file=c:/altera/13.1/ip/altera/altera_pll//source/top/pll_hw.tcl" "-- Nevertheless, this is probably not the cause since I can see the same with Quartus 13.0sp1. Any ideas?
