Platform designer/NiosII Eclipse: SRAM controller error
Hi all,
I'm getting the same error when I'm using onchip_memory_2.0.
I just installed wsl, but it doesn' work.
When I open Eclipse this error is shown:
INFO: Finished loading drivers from ensemble report.
INFO: Tcl message: "STDIO character device is jtag_uart_0"
INFO: Tcl message: "No system timer device"
INFO: Tcl message: "Default instruction linker sections mapped to onchip_memory2_0"
INFO: Tcl message: "Default data linker sections mapped to "
SEVERE: Section ".rodata" has no memory region mapping.
WARNING: Tcl script "bsp-set-defaults.tcl " error: Section ".rodata" has no memory region mapping.
SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.rodata, .rwdata, .bss, .heap, .stack]"
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings failed
nios2-bsp hal . ../../nios_test.sopcinfo --cpu-name nios2_gen2_0 failed
