Pipeline Factor in SignalTap
In SignalTap there is an option to add the Pipeline to the signals. Should the pipeline acts as synchronizers? Will the set_false_path constraints be added automatically?
Thanks!
Debug Tools User Guide explains:"The Pipeline factor setting indicates the number of pipeline registers that the Intel
Quartus Prime software can add to boost the fMAX of the Signal Tap Logic Analyzer."https://cdrdv2.intel.com/v1/dl/getContent/667125?fileName=ug-qps-debug-683552-667125.pdf
Not related to synchronizers. There's no specific feature to support the consistent capture of asynchronous signals. Signaltap operation is described so:"Synchronous sampling of data nodes using the same clock tree driving the logic under test."
Frank
- FvM
Frank
- FvM
The same way as it does for other synchronous designs. As you know, fmax of a synchronous design is restricted by the propagation delay of the combinational path between two registers. Pipelining allows to cut the path into shorter parts and thus increasing fmax.
I presume that Signaltap logic will use all available methods of timing driven synthesis, e.g. register retiming, to achieve the defined clock speed. You don't need to care for. Pipeline factor enables an additional degree of freedom for Signaltap timing optimization. - ShengN_altera
Do you find the clarification above helpful?
Let me know if you have any further concern or consideration.
Sheng
- amildm
Contributor
How can adding the pipeline registers increase the fMAX? Should re-timing be applied to these registers? How?
