Pipeline Factor in SignalTap
- 3 years ago
Debug Tools User Guide explains:"The Pipeline factor setting indicates the number of pipeline registers that the Intel
Quartus Prime software can add to boost the fMAX of the Signal Tap Logic Analyzer."https://cdrdv2.intel.com/v1/dl/getContent/667125?fileName=ug-qps-debug-683552-667125.pdf
Not related to synchronizers. There's no specific feature to support the consistent capture of asynchronous signals. Signaltap operation is described so:"Synchronous sampling of data nodes using the same clock tree driving the logic under test."
Frank
Do you find the clarification above helpful?
Let me know if you have any further concern or consideration.
Sheng
- amildm3 years ago
Contributor
How can adding the pipeline registers increase the fMAX? Should re-timing be applied to these registers? How?
