Pipeline Factor in SignalTap
- 3 years ago
Debug Tools User Guide explains:"The Pipeline factor setting indicates the number of pipeline registers that the Intel
Quartus Prime software can add to boost the fMAX of the Signal Tap Logic Analyzer."https://cdrdv2.intel.com/v1/dl/getContent/667125?fileName=ug-qps-debug-683552-667125.pdf
Not related to synchronizers. There's no specific feature to support the consistent capture of asynchronous signals. Signaltap operation is described so:"Synchronous sampling of data nodes using the same clock tree driving the logic under test."
Frank
Frank
