PCIe IP example error: Failed to open design unit file "../../../top_core.vo" in read mode.
Hi Christophe,
Thanks for the update.
Before loading the MegaWizard tab (which is after double-clicking the IP Compiler for PCI Express from the IP Catalog), please select 'Verilog' as the IP variation file type in the SaveIP Variation tab. So that the generated files are in Verilog format. After the IP generation, please confirm that the *_core.vo appears under your working directory. Alternatively, you may check it in the ip html report file which lists each file generated and provides a description of its contents.
Ven
Hi Christophe,
Have you had a chance to try the suggested solution? If so, were you able to generate the *_core.vo file?
Ven
- Christophe10 days ago
Hi Ven,
I am currently focusing on VHDL, and on these tickets:
So you can close that current ticket if needed.
Best Regards
- VenT_Altera9 days ago
Hi Christophe,
Thank you for your update.
I understand that you are currently focusing on the tickets you referenced. In that case, I will transition this thread to community support.
If you have a new question, feel free to open a new thread to get support from Altera experts.
Ven
