11 years ago
Out entity parameter as function argument
Hi!
Let me begin from code example:
entity three is
    port (do3 : out std_logic_vector(2 downto 0));
end entity three;
entity Test is
    port (data : out std_logic);
end entity Test;
architecture Test of Test is
    type onetwo_t is record
        one : std_logic;
        two : std_logic_vector(1 downto 0);
    end record;
    function convert (lv : std_logic_vector(2 downto 0)) return onetwo_t is
    begin
        return (one => lv(0), two => lv(2 downto 1));
    end;
    signal onetwo : onetwo_t;
begin
    three : entity work.three
        port map ( convert(do3) => onetwo );
    data <= onetwo.one;
end architecture Test;
So, I want call function convert with out parameter data in left hand side on entity instantiation. In Quartus I got error:
Error (10344): VHDL expression error at fifo_rl.vhd(198): expression has 2 elements, but must have 3 elements
Error (10344): VHDL expression error at fifo_rl.vhd(198): expression has 3 elements, but must have 2 elements
where fifo_rl.vhd(198) is line with convert function call.
But this code works with ghdl.
So, is it possible to do such function calls?
    I think this is a bug with with quartus vhdl compiler, as a colleague just had exactly the same problem. The work around is to use an intermediate signal.
    Raise an issue with quartus mysupport, maybe they'll fix it one day.
    You have the following instantiation:
    But you cannot have a function call as a formal in a port map. That is not legal VHDL.
    --- Quote Start ---
    --- Quote End ---
    Wrong, it's perfecctly legal VHDL. You can have a type conversion as long as it has only a single argument on either the LHS or RHS of a port map assignment.
