VSavi3
3 years agoNot able to do fitting design with Quartus 22.1
Hi, I am able to fit the attached design with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition. However, I can fit the design with ease in Version 19.1.0 Build 670 09/22/2019 SJ Standard ...
ShengN_altera
3 years agoHi,
Then I think probably have to get a larger device. Migration from 19.1 to 22.1 most likely will involve many things being upgraded which probably will cause higher utilization. So now I got both fit reports of 19.1 and 22.1. By comparing between Fitter Resource Usage Summary of 19.1 and 22.1, clearly can see that it's quite full for 22.1 compared to 19.1 even ALMs utilization (114%) also had been exceeded 100% (image below). I would suggest that getting a bigger device.
Sheng
