VSavi3
3 years agoNot able to do fitting design with Quartus 22.1
Hi, I am able to fit the attached design with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition. However, I can fit the design with ease in Version 19.1.0 Build 670 09/22/2019 SJ Standard ...
ShengN_altera
3 years agoHi,
So you mean the design used for both 19.1 and 22.1 are exactly the same? But why the .qsf provided for both 19.1 and 22.1 showing differently at the partition and logic lock assignment? In GUI, can you go to Assignments -> Design Partitions Window and Logic Lock Regions Window to confirm about it.
Need to make sure the design used for both 19.1 and 22.1 are exactly the same.
Sheng
